Store
Get directions
Stainless Steel Necklace Chain 2.3mm Petite Cable Chain with Lobster Clasp, Small Finished Chain Silver Alternative 23" 24" inch 60cm
Store
Corabella Jewellery
CAD$20
Quantity:
Add More
Add to Bag
Go to Checkout
Favorite
Favorited
View Favorites
Share
Share
Pin it
Store
Corabella Jewellery
Matinee length stainless steel cable chain with lobster clasp closure.
* stainless steel
* length: 23 inches (59 cm) - sits below collarbone and most necklines.
* chain width: 2.3mm
* link size: 2.8 x 2.3 x 0.6 mm
* surface sheen: shiny
The end loop is 4.1 mm outside diameter. If you will be adding your own pendant, please check that the bail is big enough to fit over this size.
Non-tarnishing stainless steel is a great alternative to silver plated or silver-toned "mystery metals", is strong and durable.
Once this item is sold out, we do not plan to re-stock it.
If you would like more than the available quantity shown, feel free to contact me and I will check my stock and get back to you.
Thank you!
