• Corabella
Corabella
Corabella
Square Toggle Copper Bracelet Chain, Artisan Chunky Pure Copper Square Wire Cable Chain Bracelet, Genuine Copper
Store/Corabella Jewellery
CAD$32
Chain length
Square toggle bracelet (or anklet) with chunky square wire cable chain. Handmade entirely from natural pure copper.
Chain links: 7mm x 6mm
Toggle square: 18mm x 18mm
Toggle T-bar: 30mm
*measurements are approximate.
Sizing: Measure the circumference of your wrist (or ankle) and add one inch (2.5cm). Select chain length in the drop-down menu. In-between sizes? Go up a size, or message me if unsure.
Artisan clasp may vary slightly since each one is handmade to order.
We use only genuine copper parts to make this bracelet/anklet! The pure copper is BARE and is not lacquered or sealed, so it may have oxidized areas and will tarnish over time.
Measurements are approximate.
Our solid copper and solid brass chain has some recycled content and originates from the USA. Lead & nickel free.
© Corabella Report abuse
