One (1) necklace chain with artisan clasp. All necklace parts are solid copper.
Etched links (see close-up to see texture).
* chain link size: 4mm x 5mm
* wire thickness: 1mm
* 8 links per inch (approx.)
Handmade solid copper clasp hooks through the end loop of the chain.
The end loop of the chain is 5.5mm wide. If you will be adding a pendant to this chain, please check that the bail is large enough for the chain to fit through.
This pure copper chain is bare, not lacquered, and may have some natural oxidation.
Measurements are approximate.
Our solid copper and solid brass chain has some recycled content and originates from the USA. Lead & nickel free.
If you would like more than the available quantity shown, feel free to contact me and I will check my stock and get back to you.
