• Corabella
Corabella
Corabella
Round Chain Copper Bracelet, Etched Circle Cable Chain, Textured Solid Genuine Copper Adjustable Bracelet, Artisan Pure Copper Anklet
Store/Corabella Jewellery
CAD$28
Chain Length (inches)
Round link cable chain bracelet in genuine copper with artisan clasp. Adjustable length. Simply hook the handmade clasp through any link for a custom fit.
● Chain design: round cable links with lines etched in a spiral pattern
Chain link size: 10mm, 3.4 links per inch (approx.)
● SIZING / FIT:
Measure the circumference of your wrist (or ankle) and add one inch (2.5cm). Select chain length in the drop-down menu. In-between sizes? Go up a size, or message me if unsure.
We use only genuine copper parts to make this bracelet/anklet! The pure copper is left bare (not lacquered) and may have some natural oxidation. Genuine copper develops patina over time with exposure to air and moisture. To shine it, simply buff with a small amount of metal polish or soak in vinegar for a few minutes, rinse and pat dry.
Measurements are approximate.
Our solid copper and solid brass chain has some recycled content and originates from the USA. Lead & nickel free.
If you would like more than the available quantity shown, feel free to contact me and I will check my stock and get back to you.
Thank you!
© Corabella Report abuse
