One (1) adjustable bracelet chain (or anklet). Natural gold color solid brass.
Adjustable length. Simply hook the handmade clasp through any chain link.
Choose your chain:
1) Square wire cable chain, 5mm x 7mm links
2) Ladder chain Round 5mm x 8mm links (each link connects twice to its neighbour)
3) Ladder chain Square, 5mm x 10mm links.
4) Large Round textured cable chain, 10mm wide
Sizing: Measure the circumference of your wrist (or ankle) and add one inch (2.5cm). Select chain length in the drop-down menu. In-between sizes? Go up a size, or message me if unsure.
Handmade clasp hooks through the links to adjust length. Clasp may differ slightly from that pictured.
This bare solid brass chain is unplated and unlacquered. It looks like a gold color.
Please note: 1) this chain can oxidize slowly over time. I find that when I wear it a lot, it stays nice & shiny. It can be polished just like sterling silver if desired. 2) this chain does not contain gold metal, it is a gold colour.
We have done our best to photograph the true colour of this chain in natural light, however due to variances in viewing screens, actual colour may appear somewhat different than in photos. The clasp color may differ slightly from the chain color.
Measurements are approximate.
Our solid copper and solid brass chain has some recycled content and originates from the USA. Lead & nickel free.
If you would like more than the available quantity shown, feel free to contact me and I will check my stock and get back to you.
Thank you!
