• Corabella
Corabella
Corabella
Adjustable Stainless Steel Necklace 3.7mm Small Cable Chain with Lobster Clasp
Store/Corabella Jewellery
CAD$20
Matinee length stainless steel cable chain with lobster clasp closure. Can be adjusted shorter, as the clasp can connect to any link.
* stainless steel
* length: 23 inches (59 cm) - sits below collarbone and most necklines.
* chain width: 3.7 mm
* link size: 3.7 x 4.8 x 0.9 mm
* surface sheen: shiny
The end loop is 4.1 mm outside diameter. If you will be adding your own pendant, please check that the bail is big enough to fit over this size.
Non-tarnishing stainless steel is a great alternative to silver plated or silver-toned "mystery metals", is strong and durable.
© Corabella Report abuse
